- Dec 20, 2005
I just bought my second Spyderco Native in CPM S30V. (The first didn't have any problems).
I was cutting up some heavy cardboard boxes this morning (I didn't hit any staples) and then tried to slice some paper, immediately I noticed two very small chips in the blade as it wouldn't cut smoothly (it would snag on these chips and tear the paper).
I decided to submerge the handle portion in a cup of water (to protect the handle from heat) and used a propane torch to gently heat the blade. I heated it slowly until it turned a "straw" color and then let it return to room temp. I then resharpened it using the Sharpmaker at 30 degrees total (30 strokes with the medium coarse rods and 20 with the fine).
I went back to the same cardboard, cut twice as much as I did before and then tried the paper, it sliced it easily. It would also shave hairs very easily afterwards.
I'm not saying that this is a cure for everyone, but it worked for me.
Has anyone else tried this? It probably would have been better to remove the blade and temper it in an oven, but it's riveted onto the handle. Is the chipping generally related to the particle metallurgy technique or is it the result of heat treat? And if it is, perhaps the steel was not tempered at a high enough temperature?
