Princeton Tec Scout
a while ago i did a review of a new headlamp i had bought, a cheap Energizer one. i have had it for a while, but i have grown tired of its bulk and weight, so i decided since i had some $$ burning a whole in my pocket, i would poke around at some better quality ones.
i ended up at Dick's sporting goods, looking at their isle cap display of Princeton Tec headlamps, among others. the Scout model caught my eye as being small and light, with good run times and pretty good throws.
it cost me all of $22, only about $7 more than the cheapie.
so...
the cheapie weighs just shy of 5 oz. the Scout weighs just shy of 2 oz. 3 oz doesn't really sound like too much, but in something this size, it makes a huge difference.
the mechanism that allows the light to pivot on the Scout seems fairly unique based on my observations of the headlamps on display with it (including the other Princeton models). it is a simple pivot made from the plastic casings of the two parts, but it has a small screw that allows the tension to be adjusted. it came fairly tight, so that it takes a grip with two hands to rotate the light. i like that, the cheapie has a simple ratchet style adjustment. it never took much for the ratchet to let go and drop the light to point at my feet, because the plastic wouldn't hold terribly well. this made it a hassle to wear running, which the Scout should do well for.
the Scout takes two watch batteries, which are not as readily available as the AAA that the cheapie takes, but i'm willing to put up with that for the drastic difference in size and weight. interestingly enough, the Princeton AAA model (that takes the same number of batteries as the cheapie) is about half the size of the cheapie, which is a nice feature if you want to go for the slightly greater light output and availability of batteries.
the general construction is something worth mentioning on its own. the screw that holds the whole thing together is designed so that it cannot fall out once it is loosened, a very handy feature. the screw is a slot style designed to be screwed with one of the plastic adjustments on the strap, but will also fit all of the USA coins in circulation now, if carried without the strap. everything is very solid looking and simple on the inside, the batteries being on the same level as the two LED bulbs, with easy access for changing.
the Scout also features an integral clip, that allows the light to be clipped to the brim of a hat or cap in leiu of using the head strap, another nice feature.
operation is a bit tricky to figure out at first with the Scout, but i had it in about 5 minutes of playing. its actually really neat. if you hit the power button several times in quick succession, it will click through the different power modes (bright, less bright, even less bright, and blink). if you hit it once, pause for a couple of seconds, and hit it again, it will simply turn off instead of going through the further power modes.
overall, i'm very happy with this purchase, and i wish i had made it sooner. this will reduce weight and volume in the pack without reducing actual light output, which is a good thing in my book. it will also be more comfortable to wear, and be less bouncy when i'm moving around.
a couple of pics:
the Scout on the right in all cases.
the batteries in the Scout are those that came with it, and the batteries in the cheapie are pretty fresh, to give you an idea about light output. both feature two LED bulbs here, the cheapie being in the "flood" mode and the Scout being in "full power" mode.
any questions etc don't hesitate to ask!;)
Nice write up Simon!
I have two Princeton Tec lights. One Fuel (for small and lightweight) and one EOS for a little more light output.
One of the things that I like about Princeton Tec is the use of Lithiums. Some companies (specifically Petzl) says do not use them. Other companies don't really say. Princeton Tec states that lithiums are okay. Why is that a big deal to me? Low temps. Don't have to worry about keeping lithiums warm when cold weather camping.
I stayed away from headlights for the longest time. But, they are just so darn convenient. Especially when it is cold.
I am glad you like the light.
Nice review. For some reason, which I cannot fathom, I always loose headlamps. I like them. But I pretty much have lost everyone. No idea why. I manage to keep a hold of my maglightes for some reason. Thats what I have now. If I buy a new headlamp next year, it will be a cheapie, as I've lost running 3 of them in the past two years now.
great review simon...:thumbup: those are cool little headlamp's... i keep one in my camelback, when i mtn.bike... just in case...
haha, Im the same way. I've had 4-5 over the last 3 years and I have no idea where the are now, they were cheapies but man they are nice to have around camp, or in the tent. Setting up tent after dark, a headlamp is extremely handy.
Great review Simon, I now know what Ill be picking up next time I get one, thanks:thumbup:
I looked at those long and hard for a while. They are a compact little light.
There are two main differences between the AAA batts and the 2032. The first is capacity, as 3 AAA batts will hold about 10-15 times the juice of 2 2032. That makes a difference in how bright and long the light runs.The second, which is not applicable to all, is that there are easy rechargeable solutions for the AAA. If you use the light a lot, this is a nice feature.
For cheap 2032 batts, try dealextreme dot com. They have them for something like 30 cents apiece. Not as good as storebought, but a lot less expensive. You can also raid them out of clearance priced keychain lights sometimes.
Any Cal, thanks for that tip on battery sources, i'll keep that in mind.
i will mostly be using the Scout for camping specific purposes, and use the cheapie around the house when i need hands-free light, so i'm not really too worried about the battery run time difference.
the battery thing was a factor when choosing a new camera a while ago though...i went with AA after having to deal with a single rechargeable proprietary battery on the last camera. now i use rechargeable AAs and keep a spare pair handy...works much better.
just wanted to offer an update:
after having used this light for a couple of nights in the woods, i have formed some more complete opinions on it.
i am still happy with this light, but i have noticed that the small, semi-stiff button is a little difficult to press. not a deal breaker, but something to consider for winter camping or if you simply have large, clumsy fingers.
I have used a Princeton Tec EOS for several years now. It is larger than the Scout, but very durable. I rarely even bring another flashlight along now, other than my Photon squeeze light. I couldn't get by with just a flashlight as it is so convenient to be able to use both hands for camp and horse chores after dark.
I like my Eos, and still use it and the Aurora on occasion - but I recently received a Zebralight h50 headlamp, and it rocks. 3 levels of light (2.6 lumens, 13 lumens and 66 lumens), off a single AA battery, and it's a nice flood-type pattern - great for when you need bright light for detail work. It's also very lightweight - 2 oz w/ battery installed.
Price - well, it's not very cheap (around $70).
I got mine from 4sevens.com
