- Oct 6, 2005
I have a question about etching your initials, name, or logo/makers mark onto a knife blade I've made. I saw a video on UTube made by Nick Van Leuven on how to etch your makers mark onto a knife blade. I was interested in learning how to do this since I make make fix blade knives and would like to have my mark etched onto the blade. In the video he uses a 12 volt batter charger, white vinegar and salt for the acid etch. You paint a substance on the area of the blade you will be etching. He uses nail polish and then writes his initials into the polish exposing the blade. He then attaches the positive lead of the 12 volt battery charger set to 6 amps to the blade. He mixes the vinegar and salt solution and dips a cotton swab into it. He then attaches the wet end of the swab to the negative lead of the charger and touches the swab to the exposed initials which starts etching into the blade. He does this for a few minutes then removes the nail polish showing the initials etched into the blade. I have tried this five times now and can not get any reaction where my initials are etched into the blade. Can someone tell me what I'm doing wrong? Does it make any difference if the blade is already heat treated or if the metal is stainless steel? When you touch the soaked cotton swab to the exposed blade is should start bubbling but there is not reaction. Yes the power is on. I have tried setting the 12 volt battery charger to 6 amps like Nick suggests. I've also tried 9 amps, 12 amps, clear up to 50 amps with no reactions. The white vinegar I'm using is the kind you buy at the grocery store. It's comes bottled in a solution diluted to 5%. Do I need a stronger solution of vinegar. This is all I can find. Any suggestions or tips would greatly be appreciated. Thanks Guys.
