Hammer and punch those out.
Vise, or nuts, washers and threaded rod act as a press to press them in.
Plenty of youtube videos on that.
Get the bearing number off the ones you take out.
Get sealed bearings next time.
What you want to fix ? Did you try that wheel on grinder ? I can t see clear on that short video , but seems to me that there is some thin tube as spacer thru bearings and sound come from there ?? If I m right when you tight wheel everything would be OK . Picture would help more ....
This is new 4" contact wheel. Can I fix it myself? I have no press machine.
Thank you for your help.
They are sealed bearing as much as i can see ?Get the bearing number off the ones you take out.
You're right. I wanted to fix the tube between bearings. And I did it.What you want to fix ? Did you try that wheel on grinder ? I can t see clear on that short video , but seems to me that there is some thin tube as spacer thru bearings and sound come from there ?? If I m right when you tight wheel everything would be OK . Picture would help more ....
What you fix ? How you fix ? What was wrong with that tube ?You're right. I wanted to fix the tube between bearings. And I did it.
The tube is located between the bearing and the bearing. I hit one bearing with a urethane hammer.What you fix ? How you fix ? What was wrong with that tube ?
Seems to me that you tried to fix non existing problemThe tube is located between the bearing and the bearing. I hit one bearing with a urethane hammer.
