- Apr 11, 2011
Hello guys;
Im having trouble to get a nice finish on my Spyderco tenacious which i had a lousy attempt before for mirror finish.
I disassembled knife, secured at a vice and sanded with each grit different direction.Blade is ffg but wasnt perfect so when i sand with flat hard surface sanding wasnt consistent.doing with finger yield better results.
360,400,500,600,800,1000,1200
And hand polishing with metal polish.(which is not aggresive i guess)
After 1200 and polish i could still see the marks from sanding.
This photo is with 1000 grit(cant find 1200 paper , i re-did the whole blade 3 times probably
Should i go to a kinda long trip to get more finer sandpapers for mirror finish? or its too much to ask without buffer and compounds?
Also what do you guys recommend for sanding block that have some give?
Then i tried to have satin finish with paralel sanding with 600 grit.I read you shouldnt make back and fort for final step for satin finish just straight pulls still not very consistent either as you see.
Should i go back to 320 grit and stop at 800 grit for a meh satin finish?I still can see marks from previous grits
This blade is hard to work btw you cant really sand the area where the grind ends when you are sanding paralel.
This is the finish i would really like to achive btw;
