Hi! I have a problem with my Kershaw Scallion, basically I disaseembled and reassembled it and it's not working fine anymore...
Lately, the openning of my Scallion started to be less smooth than usual, because of the dust I think, and I decided to clean it and lube it. It's my first time disassembling a knive with the assisted openning system. I had no problem at all with the screws, I cleaned and lubed it with gun oil and reassembled it, now I can't get it to work properly again...
I have disassembled and reassembled like 10 times, adjusted the pivots screws in all ways, and cleaned and oiled it 3 times.
Now it kicks out the blade like always but stops halfway, It's like ther's some friction in the second half of the motion and that stops the blade, maybe because of the liner lock preassure in the blade... I don't know what more to do, the spring is working fine and I softed the screws a lot and it was the same...
Anyone experienced the same thing?
Maybe I lost a washer in the disassembly process (I have two, one silver and a golden smaller one) or I have to use another kind of lube instead of the gun oil I used...
I can post some pics of the disassembled Scallion in case it helps to find the problem.
Thanks a lot for the help!!!
