Problems with a Zaan - can anyone help?
Here's the post:
Hey blade forums. I've got two problems with my relatively new umnum. Looking for some input. The first, is that I can't get the action back to how I want it. The second, is that the clip rattles. Details -->
I've had my umnumzaan about a month now. I bought it second hand here on BF and it was "like new." There was still some of the CR' fluorinated grease in the pivot when I first got it. The knife was very smooth, but the action was easy.
After a couple weeks of carry and use, the knife got gunked up. I took it apart. The breakdown was easy. I used 10w nano oil to lubricate the pivot (it's my best lubricant I have) and put it all back together. It's the new umnumzaan with the small pivot.
The breakdown was very simple. There are the two perforated bronze washers, and a pivot screw on each side. One of them has threads, the other is a tube. Very simple. I build it all back up the way I broke it down. No problems.
Now that it's back together, it's just not that easy action I was expecting. It's smooth, but not easy. I understand that the nano oil is thinner than the CRK grease. Do you guys think that's the problem?
I called CRK telephone service number. They say basically that I over tightened the pivot and the nano oil should not be the problem. I tried the pivot at varying tightnesses.. I just can't seem to get it to that "perfect" combination.
The knife is so simple and it doesn't have too many parts. Was wondering if anyone has experience and help clarify this issue for me. Possibilities in my head so far are:
1) Lubricant too thin. Maybe heavier weight or the specified CRK grease is whats needed to fix it.
2) Not tightening it down just right.. I'm not 100% on this but I've tried a lot of different positions of the pivot. Some slight blade play when its loose, and even almost as tight as it will go. The action is mostly the same in all different tightnesses.
3) Maybe flipping the washers or hardware around?
The second issue is that the clip rattles. It's been like this since I got it. There is a slight mark in the titanium of the clip at a bend point, as if it got bent or hooked on something. If the knife is out and in the locked position, it clicks against the lockbar quite often. Nothing a huge deal, but somewhat annoying. If I press the clip toward the lockbar, it will fix it for a little while, but the rattle comes back every time. The rep said she things the clip screw is stripped and thats whats causing the rattle. I examined it and found one of the threads of the clip screw is indeed stripped. Thoughts, experiences on this? Do I need a new clip screw? I new clip completely? Is it supposed to rattle?
Thanks in advance for your input!
-Adequacy
The tread has been moved here.
