- Mar 19, 1999
I am a new maker, and am working on a few knives right now, and I had two problems I have never had before both happen today. I made a litle spear point blade, I just finished polishing the blade, and I was getting ready to put on the handles scales. I wiped everything down with acetone, and I mixed the epoxy(devcon 2-ton) in a little 2 oz portion cup like what you would get salad dressing in a restaurant. I started to butter up both scales, by the time I started to put some epoxy on the blade tang, the epoxy was hard in the center of the portion cup, I tried to hurry but the stuff was completely hard and unspreadable in under 4 minutes after mixing? What the hell happened. I scraped off all the epoxy I could of the blade and scales and I will just have to glue them later, but I can't figure out what happened with the epoxy, i was in my garage, the temp was about 77-80degrees farenheit, I mixed it up the same way I have done 20 times before using a scrap peice of kydex. What could have caused this.
Now my second problem, I just finished a wharncliffe style neck knife with rosewood scales. I was all finished except for putting the final edge on the blade, and it was the first blade that didn't have any mistakes from start to finish that I could see. I actually thought I was finally getting the hang of things, but when I put the final edge on the blade, instead of a straight cutting edge, it is sort of wavy. The blade seemed straight along the edge before I put the final bevel in it, it was at least as straight as I can see with my eyes, so why did the edge get all wavy? Any one have a suggestion?
any help would be great.
thanks guys,
Kyle Fuglesten
thanks guys,
Kyle Fuglesten
