For starters how do I establish a convex grind, hollow, or flat grind with a sanding belt (flat or round)?
Hollow is done on radius on the rounded curve of the sander? How do I determine how wide + how the angle of the hollow grind would be in relation to the thickness of my blade?
Convex can be done on all types of sanders? You just have to rock the blade slightly?
Flat grind can only be done on a flat belt of the sander NOT the rounded part of the sander?
How would you change from one grind to another? From hollow would you turn it into a flat grind first in order to make it a convex?
