Processing abalone
Hatchet_Jack
Basic Member
Gday guys,
I’m not a knife maker, but someday I’d like to be. Currently I take apart old folders and put them back together with different scales etc.
My father in law went diving over the weekend and brought me back some abalone. How do I go about processing it for knife scales? Seems like it would chip fairly easily and being very thin I don’t know how to make it work.
Any suggestions before I start going hammer and tongs myself would be appreciated.
Cheers,
Jack
Most of the "abalone" knife handles you see are actually made from glued together flakes of abalone shell.
About all you can do with those is saw them into pieces as long as you can, and flatten the pieces. You probably won't get any big enough for handles, but you can use it for inlays.
I've processed a lot of abalone. My brother was an abalone diver in CA many years back. I still have a box of uncut shells somewhere in the shop.
The first thing I want to say is the things you read online about it being deadly toxic or having cyanide is false. No dust is good to breathe so wear a face mask or a respirator, but abalone is just shell - calcium carbonate and other organics. It makes a lot of fine dust, so have a vacuum running with the nozzle right at the sawblade or belt sander. Vacuum up all the dust off you and the work area when done.
Cut it with normal tools. I use my metal cutting bandsaw. You can use a coping saw with a metal blade or a hacksaw. Sand it with any normal abrasive that works on wood or metal. However, if a tile cutting "wet" diamond saw is available, by all means us that to cut the shells.
As Bill said, cutting a slab of abalone will only get a small piece of usable material. It would great for inlay and small scales on folders, but a large colorful piece is rare.
When working it you have to decide when to stop grinding. Going "just a little deeper" can go right through the color and give you only dull shell.
When cutting the shells, start by slicing the shell into the longest strips you can. Usually, you get one or two strips. Lightly sand the surfaces and see what it looks like. As you flatten the pieces, pick the side that seems it will have the best color. Surprisingly, it may not always be the inside. Dipping in water or using a water mist helps a lot with keeping the dust down. I suggest doing it outside or having a vacuum running right where you are sanding/cutting.
Once the pieces are flattened down mark where the best color is and go from there in cutting the scales you need. Polishing is just sanding to around 800 grit and buffing with matchless white. DON'T let it get HOT!
Sometimes, a better use is to make a decorative stand or an ornament from the shell. Sand and polish the outer surface until it looks beautiful and use it to display a knife on at a show or as a windowsill or table decoration in the house. I have also seen them made into candlesticks by attaching a candle holder on the top. The alternative is to make your own composite scales. It can be done by fitting a mosaic of many colorful smaller pieces on a thin piece of G-10 and grinding them down. With the trend for casting resins, you can also crush the colorful stuff and cast a resin blank to use for handle scales.
These posts threads have more info you should read:
Thank you very much for the information and links. I’ll head down this path. Much appreciated mate.
