Professional Kitchen Knife
Hi,
This is a Professional Kitchen Knife "Haute Cuisine" I just finished.
N678 Stainless Steel, 9 1/2" usable edge, 13" overall length. 4mm spine thickness at the handle.
Handle in stabilized and lacquered Arca wood with hand made bronze and stainless steel pins.
It has a very ergonomic handle and the edge continues under the handle about 1", so the cook can apply extra pressure to chop or cut a bone.
It'll have a handmade leather envelope style sheath.
Regards,
Ruben
oh thats nice! I like the handle on this one :D
Ruben,
That's a beautiful design. Very unique. How does it perform in the kitchen?
I'm not familiar with N678 Stainless Steel. What other steels is it comparable to? How hard is it? How is its edge holding ability?
The reason I ask is that my wife is a professional chef and has recently come to appreciate "nice knives" with better steels as they perform better and longer than the junk most chefs use. I am looking for high end knives with which she might be happy in her work. Slicing ability is the key for her... its got to slice like the dickens for a long time before it needs to be resharpened. She has a cleaver for serious bone breaking so this knife needs to be a cutter.
At any rate, gorgeous knife. I'd love to know more about it (hardness, performance characteristics, cost, etc.).
Many thanks!
AJ
Thank you very much :)
N678 is an Austrian steel, similar to AUS8, with some added Vanadium (you can check a little comparation table here: http://www.calocustomknives.com.ar/docs/aboutme_materials.htm)
This knife has a hardness of 57-58 RC.
The reason behind this hardness is that I always prefer to have an edge that you can retouch with a regular sharpening rod in 2-3 seconds that an edge that lasts a little longuer but that you have to use specific tools to sharpen it.
A butcher, cook, or chef knife should be razor sharp at all times, and with this hardness, I make sure that it will perform well and that when the user wants to mantain the edge, s/he can do it in no time and keep on working.
If before using it again, you give the edge a couple of touches with a sharpening rod, the knife will have a scary edge for years, the key is to mantain the edge instead of letting it dull and then re sharpen it. (And of course, if you're working and realize that its not cutting like it used to, you can use a rod and you'll have it hair popping sharp again)
I tested it for some days in my kitchen before giving it the last polishing and sharpening and I was very happy with its performance. I used it to cut tomatoes, lettuce, meat, etc and after those preparations it was still sharpen enough to cut paper with no problems.
I did modified something on this design from the regular chefs knives I've seen/handled.
When working with a chef's knife, proper grip is to pinch the blade between the thumb and forefinger, but since I extended the blade to be under the handle too, I added a little recessed area on the handle slabs so you'd pinch this speficic part of the handle instead of a thin blade, thus allowing the user to execute more pressure and a better grip (not so slippery as the cold steel)
I think it's more comfortable and ergonomic to pinch something with this thickness instead of a thin blade, making it more comfortable to use for extended periods.
You can see that area better on the last picture. It might appear that it's too far behind for a regular knife, but it's compensated by extended working edge below the handle/hand knuckles, with the benefits just explained.
That is if you want to keep the traditional grip for this kind of knives, but if you want to use other type of grip, you can also grab the handle closing all 4 fingers and since the edge is right beneath your fingers, you can apply pressure to slice in this grip too.
If you have any other questions, please don't hessitate asking me again.
I'll send you an email regarding price, as I'm not suposed to post numbers here :)
Regards,
Ruben
Ruben,
Many thanks for the information! I appreciate your timely and straightforward response, including your email.
We're in the process of discovering a knife that suits my wife and your latest creation is certainly one we're looking at quite seriously.
AJ
Very nice work indeed. The design looks very useful for kitchen chores, I like it :)
Nick
