Sorry RampmasterSet-Pro, Rampmaster, Genesis, or TAP?
The step 3 is the one I don’t remember how to programStep #1 - Ramp at rate 9999 to 1200F, hold for 15 minutes ( insert steel)
Step #2 - Ramp at rate 500 to 1400; hold 1 hour
Steps #3 - Cool to 1000 at rate 40
Step #4 - end program.
I have wondered for a while if with a cranky steel like L6, could you quench and then subcritical "temper" anneal instead of having to run your oven at relatively high temperatures for 12-14 hours? ?
What’s that process?I have wondered for a while if with a cranky steel like L6, could you quench and then subcritical "temper" anneal instead of having to run your oven at relatively high temperatures for 12-14 hours? ?
So just set target temp as 1000 and rate as 40f?I think it is the same as ramping up, set the rate, set the temp.
Hoss
Forged a test blade from a new batch of L6(Moly). Let it cool on the bench and as expected was probably 60rc after air cooling. Then ran the cycles you suggested and it worked great without tying my kiln up for 15 hours. Soft and easy to grindI’m not real familiar with L6, I would try 1600’ for 15 minutes to normalize, air cool, 1450’ for 15 min, air cool x 2 times, 1450’ for 15 min, oil quench. 1200’ for 2 1/2 hours, air cool = fine spheroidite. This would be a very good condition to austenitize and quench from.
Hoss
