Not on this one, hand cutting the actual holes on mine was BRUTALSweet! Is that going to have exposed internals? I wonder if there's a way to fit some tritium in there.
looks good....
He shows in the first post that these scales are made by Dalton Rosenfeld. I don't think the scales alone are enough to swap the clip though. I'm pretty sure you would need to drill and tap the frame.Do you think it would be possible for someone to make aftermarket titanium scales that allow the pocket clip to move to the reverse side for lefty carry?
If so, who might be such a person?
That's correct, it would require an aftermarket front scale with the clip milling and holes as well as modification to the frame.He shows in the first post that these scales are made by Dalton Rosenfeld. I don't think the scales alone are enough to swap the clip though. I'm pretty sure you would need to drill and tap the frame.
