Promontory Peg Deadfall Trigger Revisited
I've known about the Promontory peg for some time now... and a few years ago I caught a rat using this trigger. But I had always found it to be a bit frustrating to set. It either seemed to be unstable... or not sensitive enough for small rodents. Also, I've had great success with the figure four trigger and I have found that it can be set to be very sensitive while supporting a heavy weight. So up until recently I hadn't given much thought to the Promontory peg.
The presence of rats and mice in my back yard got me thinking about traps again. I'd caught a few in store-bought traps, yet the rats in particular seemed to be avoiding the traps.... no matter what I baited them with.
Anyway, my thoughts returned to the Promontory Peg. I could be wrong, but I understand that the name given to this trigger mechanism comes from the place where some old peg artifacts were found. A challenge was issued to see if anyone could figure out what the function of these artifacts was.... and a gentleman called George Michaud announced that they were a deadfall trigger. George sometimes contributes to forums on the internet going by the name 'Bad Hand'.
I made some trigger sticks, and this is what I found worked for me:
- The shorter the 'thick' base part of the lower peg, the more stable the trigger is.
- The longer the tapered upper portion of the lower peg, the more leverage the critter has to set off the trigger.... and thus a small animal is more likely to be able to fire the trigger. But the peg can't be so tall that the animal can't reach the bait.
- The bait stick should face the back of the deadfall (i.e. it should be on the 'inside').
- The bottom of the peg might be best cut at an angle to match the angle at the top of the thicker portion of the bait peg (see diagram).
- The angle of the upper support stick can be critical (see diagram).
- Having a deadfall weight sitting firmly on the ground at the lower end without sliding or wobbling is very important to the stability of the whole trap. On soft ground it may be best to drive pegs in against the weight to stop it moving.
Here are some drawings which I hope help to convey my ideas:
Yesterday I made a Promontory peg set to act as a trigger under a concrete paving tile:
This little deadfall was set up on our patio just outside the lounge ranchslider. About two hours after dark we were watching a video and we heard a 'clunk'. We went outside to find this:
The rat seemed to be just a common bush rat... one of the nicer ones. I have seen a big brown rat in the yard, but it has either moved away, or is just too cunning to get caught. I'd actually set this trap for mice as I've found that they could be getting through the galvanised ventilator flashing to live behind our walls and I want to kill a few before I block the holes. Tonight maybe.
Lizzy the Dog wanted to make sure the rat wasn't coming back:
I like the Promontory peg trigger for its simplicity. And to a rat or a human it may look less like part of a trap compared to the relatively complicated figure four arrangement. Now that I understand it better and can set it to have reasonable stability and sensitivity I intend to use it more often for rodents.
Best wishes from NZ... Coote.
Hey sc, glad to see you're keeping your hand in.
Phil has played around with the P. Peg quite a bit, so I'm sure he'll be interested in this thread.
We're getting out to play in the next week or two, so we'll give your method a whirl.
Doc
Great job, haven't made one of these for quite some time....days off coming up !:D:thumbup:
I made some of these with George Michaud at Rabbitstick last year. I did some with a SAK saw and then used a stone knife. Made all the difference using the stone knife. Cutting with a stone knife perpendicular to the stick automatically created that 25* angle and a coefficient of friction to make the trap work, but very sensitive.
I understand others have their variations that work great, but there is something about using a stone knife that feels right for some tasks and this is one of them for me.
I agree... it is very satisfying to achieve something with primitive tools. I've shot a lot of wild pigs with a rifle, but the one I got with my home-made bow and an arrow made from a fern stalk gave me one of the greatest moments of my life.
Great, simple trigger. One thing I have found to help increase the effectiveness of this trap is with a baiting technique. Instead of piling a bunch of bait on the outside of the stick, I either chew or mash the end of the bait stick and work very little bait into the macerated part so the target animal has to work the stick much more and stay in the trap longer reducing missed targets.
-Xander
That is a good idea Fast14riot. I must try it. Sometimes I will split the end of the bait stick, or cut a groove in it. I then force the bait into the split or groove. Like you say, it is best to give the critters a reason to push or pull against the stick.
