- Aug 4, 2004
I just got finished building a couple of propane forges, one for myself and one for Jebediah_Smith. I already had a propane forge, but I found that it was much too large for working on knives, and it would waste heat. The larger forge would also take a long time to heat up.
Here's a picture of the finished forge. It was kind of dark when I took the pictures so they are pretty fuzzy.
http://www-personal.umich.edu/~robgaunt/pics/newforge/forge.JPG
This one is 14" long and 8" diameter. The inside is lined with 2" of ceramic fiber blanket for insulation, and has a floor made out of soft fire brick. I coated everything with a heat-reflective refractory. It has two venturi burners. On this forge, I used smaller burners, so it runs at a higher pressure but lower volume of propane. This seems to give increased suction over the larger burners, and more control.
I'm quite happy with this forge, it heats up very fast because of the smaller diameter. Here's a couple of pictures of the inside about 30 seconds after starting it up.
http://www-personal.umich.edu/~robgaunt/pics/newforge/forgeinside.JPG
http://www-personal.umich.edu/~robgaunt/pics/newforge/forgeinside2.JPG
Here's a picture of the plumbing setup.
http://www-personal.umich.edu/~robgaunt/pics/newforge/forgeplumbing.JPG
I have a bypass with a needle valve set up. The needle valve gives me fine control. I measured the forge temperature with a thermocouple, and I can control it within a couple of degrees. It also allows me to let the forge "idle" when I go work on the anvil. When you turn off the main valve the needle valve lets a little gas through to keep the burners going.
The total price for the forge and plumbing was around $100, the regulator, hose, and associated fittings cost another $50 or so. A lot of the cost was in the plumbing setup. Even though each part is pretty cheap, you need quite a few of them.
