You are very lucky that you did not blow yourself up. If you let it spew out for more than an hour you were at risk. Propane is heavy than air and will settle into the low lying areas of your yard. One spark could have potentially vaporized you and your home. If you ever have a leaky tank you need to disapate the vapor by flowing a misting hose on it until it is empty. Better yet call the fire dept. I have been witness to propane tanks exploding and the end result was horrific.thatmguy said:Well, when I went to take off the cylinder, it continued to spew propane.
Luckily I was outside. I sat it down. It was still spewing an hour later.
