The label said heat treat the same as 5160 but I curious since the steel is eutectoid it should benefit from lower austenitizing temp.
I usually heat treat 5160 at 1595F and Park50 quench... (I found you will get much harder as quenched piece with fast oil quench, none distortion problem at all)
Would 1500F with fast oil quench do the trick for 80CRV2, what you guy thought?
