- Oct 25, 2004
Another brush clearing evolution today. Halfway through or so I took a break to check the edge; I'd spent a solid ten minutes or so smashing up some very old (nearly wooden) blackberry vines that were unbelievably thick. I found an area of the edge just past the sweet spot that must've taken a pretty hard hit...a good half inch of edge was turned out quite a bit. This wasn't the edge rolling over, a lot of metal had moved. I couldn't bear down on it hard enough with the chakma to straighten it. Then I got an idea.
I gave it a good tap -- well, more of a whack -- with the side of the chakma. Half of it was straightened out! A few more taps got the rest in line. It wasn't perfect but I could smooth the rest out by just stroking it with the chakma and using a good amount of pressure. That wasn't perfect either but it was good enough to continue working. It didn't happen again. I don't remember any ground or tree strikes but I suppose it could've happened. I'm doing this cutting in some pretty rough terrain.
Is this proper use for a chakma? I'm thinking that "proper" use is doing whatever has to be done to get the edge back in place and the khuk back in action but I'm wondering if there is a "correct" method to use.
