Chris, Dion, YA BASTIDS! You're going to take me for broke!
I already have something lined up for Chris by prior arrangement a couple weeks ago, but I can't be sending this stuff all over!!!
I can tell you how to do it though.
Hold your Commander in your hand. Anchor the knife in your hand by using the pocket clip as the anchor for your fingertips.
That hand will be palm towards the floor, the spine of the knife will likewise be oriented to the floor.
You can look down and see the back of your hand.
Place the palm of your off hand on the back of the hand holding the knife.
The front of the knife should stick out of your knife hand a tiny bit and the off hand will cover this.
In an instant...
Drop the knife hand a mere 3 or 4 inches, bring it back up hard and orient the hand to where the blade will release...you bring your knife hand up hard into the stationary and waiting palm of the off hand which acts as a brake for the other hand in motion.
The blade will open by inertia.
This is a slap opening, using a slap check on your own hand, the first time I saw it was Dan Inosanto in "Sharky's Machine" open up an Imada Keibo Baton by bringing the closed baton up and then using his off hand to slap check the forearm of the baton hand.
Then, Imada had this in his book, "The Advanced BaliSong Manual," along with a small section on his baton, which was better than an ASP and ASP drove him out of business from what I understand. He was making an excellent telescoping baton before ASP was...
And yes, you can slap check to open an ASP, I have taught this as a "Hidden/Startle Technique" to some friends who are in Law Enforcement and it makes people back down really quick because 21 to 26 inches of tubular steel come out of nowhere.
If you have to hit them, you are instantly chambered for a backhand [#2 in the Filipino Arts] Strike and if they rush you and you cannot open the baton, you simply use the butt of it to smash them.
Slap checking the ASP Baton, can be done the same way, but your off hand contacts the area of the forearm near the inside of the elbow joint.
"You are no more armed because you are wearing a pistol than you are a musician because you own a guitar." ~Jeff Cooper
And the same goes for a knife...
And, I'm a Usual Suspect.
Some of my Knives and other neat things
