The thing about the Sharpmaker is that it only has two set angle slots for sharpening: 15deg and 20deg. It can be modified to handle angles inbetween and to either side, but let's just stick to basics.
I have yet to buy a blade (that I can think of) where the secondary grind (edge) is ground at precisely 15 or 20 degrees. In fact, rare if ever is it that both edges are ground at the same angle. Why does this matter when a few degrees on either side don;t "really matter"? Well, they do matter. When you have many knives, it doesn;t fit well to have to know which knife likes which exact angle for that scary-sharp edge. The answer?: re-grind your edges to a couple or few set angles.
What I do is re-grind the edge on some knives to about 12-1/2 degrees. Then, I use the 30degree (15 deg) holes on the sharpmaker each time for that knife. Each steel takes it own number of strokes on the medium rods (if you let it go that far) based on hardness, condition of the edge, and sharpness when starting.
On most of my knives, the edge rarely needs to go to the medium rods - the fine rods suffice. A few light strokes, say 10 on one side then ten on the other. Then 5 and 5. Then 5 again going one stroke per side. Strokes are light and smooth. There is no "slapping" of the knife against the stone at the beginning of each stroke. There is care taken near the tip to prevent the tip slipping off and rounding. There is care taken during the stroke to rotate my wrist to match the belly curve. The strokes end feather light - just barely touching the stone on the last three or so strokes.
Then there's stropping. I've never got a hair "popping" edge right off the fine stones (maybe I need to get a set of ultra-fines). I go to a wood-backed leather strop loaded with green chromium oxide. Smooth, light strokes, again 10 on one side, ten on the other, then alternating.... all at the correct angle. When I'm lucky, this is what gives me a hair "popping" edge (will "pop" [cut]) hairs when the knife is slowly skimmed about 1/8" off the surface of my arm. On Scandi and convex edges, I'll often move to the 6" bench grinder with a muslim wheel loaded with green or white. This leaves my Scandi-grinds with an edge that truly scares me...frightens me.
There's nothing wrong with the Sharpmaker. IT IS A BENCHSTONE, (propped up at an angle). It's fast and easy, but it takes a little work until you say "Oh. I see." At least, it did for me.
