- Aug 19, 2010
Last night while putting a 12 degree main bevel on a blade (Benchmade 3310 in S30V) using the 120 grit on the Apex Pro I noticed that the blade finish was being scratched all to hell despite my best efforts.
Now, I'm well aware of the concept of taping the blade which is the first thing I did with this knife using blue painter's tape. However, re-profiling with S30V I observed a lot of fine swarf and I frequently rewetted and cleaned the stone during the process. Due to the extra water, lower angle, and constant contact with the stone the tape became ragged and useless so I removed it. Almost immediately I observed long scratches form across the entire blade which ruined the matted blade finish. Not good.
Thankfully, this was my own knife and not a customer's but I wonder if there isn't a better way to preserve the finish on fine knives during the "traumatic" re-profiling step. So, with that in mind I'm going to purchase some acetone and quick-drying clear lacquer tonight. The idea is to carefully apply the lacquer across the entire blade (several coats) then use a paper towel or Q-tip dipped in acetone to remove the lacquer in the area to be rebeveled. Then go through the motions of removing material using the extra course, etc, all the way up to the mirror finished edge. Finally, the lacquer coating will be thoroughly removed with acetone and rinsed with water revealing a flawless blade with a mirror finish bevel (in theory).
Obviously, for work knives that are going to be scratched up anyways this isn't a necessary step, but If I run into someone wanting a scary sharp mirror finish edge while retaining a perfect finish I think this may have application. Especially on those extremely expensive knives where a single scratch would be a catastrophe.
I'll add more later including pictures as I develop a process.
Cliff notes: Protecting the blade finish by taping the blade doesn't work for me so I'm going to try a temporary lacquer coating that will be removed at the end of the sharpening process. Especially applicable on super-expensive/decorated/Damascus blades.
P.S. If you're reading this and want to try it yourself, do not apply any kind of urethane or urethane "lacquer". Once urethane cures it's difficult to remove without damaging the surfaces underneath. The key here is applying a temporary and reversible protective coating to the blade.
