- Aug 13, 2002
I know, the name is a little corny but it's all I could come up with.
Since this is more of a prototype and my second folder I decided that I had done enough on it and that time would be better spent using it daily to work out the kinks. I'll just put a brushed finish on the blade, finish the different parts a little more and replace the dummy screws but that's it. PS: Don't mind the thumb-stud, it's just a dummy one to test different lengths.
A few thoughts on design:
Trying to get a good visual ratio between the blade and handle with folders is always tricky. Usually the bolster is used to make the blade seems longer than it is so I thought why not take it a step further and move the plunge there too. Not actually a real plunge (maybe eventually give that a try too) but at least a visual representation of it. Got to make it so you see the transition as less as possible and tweaked the whole thing on the next one but I do like the result so far.
Also wanted to try the segmented handle with liners showing. I have a few more ideas to implement to make it work better (I hope) but I think we are getting somewhere there too.
Here are the specs:
Blade length: 3 1/2 OAL: 7 7/8
Grind: Flat
Blade Steel: CPM154
Liners: Titanium
Handle: Stainless steel, African Blackwood, Cow bone and Bronze
A few more pics:
I'd love to know what you guys think to see if I am the only one that finds some of these ideas interesting and worth pursuing.
Thanks for your help.
Pat
Here are the specs:
Grind: Flat
Blade Steel: CPM154
Liners: Titanium
A few more pics:
Pat
