I came across this forum after buying a Buck Bones 820 Tanto bladed knife. Intuitively, it seemed like it would serve my purpose of prying out a coin sized metal disc (shaped like a bottle cap) that is superglued into a corresponding coin sized holder. The disc is actually a nameplate that needs to be removed from a telescope mount to access a special pin underneath.
The instructions says to use a utility knife to pry it out. I tried using a box cutter but it only broke the blade. I was looking at a variety of knives and the tanto blade seemed appropriate and looked much stronger. I tried it but it seemed too thick to get in between the space of the disc and the holder. I am also afraid of doing serious injury to myself if I slip :->.
I read that a tanto blade can pierce metal. I wonder if I can just stab the centre of the disc and then pry upwards? And if I did, would I use the point or the flat front end? Or am I going about this completely wrong and need a different kind of technique or different kind of knife.
This seems like too simple a request but the telescope mount is worth almost a thousand dollars and I've already created a few nicks and scratches with my feeble attempts using the tanto blade.
Any advice would be appreciated. Thank you.
