Pict,
Ok here's my take regarding fire gear
First of all, I have to admit that I often had a hard time lighting fires in the bush, especially every time I had to or tried to rush it. No matter how, one has to find flammable materials, and soaked wet wood just won't do it.
One very useful tool to find dry wood is a large blade or a hatchet. It's not that much useful in order to cut the wood, but much more to split it, and access dry wood, or either pitch wood inside a trunk. A small blade can do it too, but it has to be a tough one... at least tough enough to baton.
For me, a SwAK or equivalent is the absolute minimum for that. A Fallkniven F1 is better in the short blade range. There are, of course, many others. Even in my smallest PSK's, I thus pack a small fixed blade. At least a SwAK in triflex (which is pretty tough for a tight and lightweight package).
Igniting the stuff is not the hardest part if you can find suitable tinder. But there are times and places where good tinder simply doesn't exists. Your rain season example is a good one. High altitudes can also be cruel places, where you can sometimes find some rachitic trees, but little bark and little tinder, especially when the mosses are burried under the snow. For that matter, I always carry some readily usable tinder. It's priceless.
One of my favourites is the classical cotton ball with vaseline. It works well and it burns long. Other than that, I make myself what I call "rocket fuel" : equal parts of magnesium dust, fat wood dust, bigger fat wood shavings, and creosote from the chimney. This stuff burns as hot as hell, and can ignite almost any poor quality tinder. I also carry some fat wood, which is lightweight and burns well.
As far as fire in concerned, I consider redundancy to be vital. Some fire starting equipment will work in a given situation, while others wont... and as the elements seem to work against you, you have to move up to "heavy artillery"... So I carry the following, and use them in order :
- Level zero : Fire steel + natural tinder. Despite the hot sparks, you need good quality tinder to ignite it with those sparks. If HAS to be dry and fluffy or very thin and flammable (thin fat wood shavings for example). So if I can find "sparkable" tinder, I use the firesteel first.
- Level one : Matches (NATO storm proof matches) : the work well in the wind/rain but last only 20 secs. To be used only with pretty dry tinder/good firestarter. They will work at any altitude and extreme temps.
- Level two : Adjustable butane lighter : they tolerate wind a little but not that much. Their most useful trait is that you can keep them burning for a long time (up to a minute, not much more). They allow to dry out some kindling a little and ignite stuff even if it's a little wet. Pick a true flint one (no piezzo-electrics !).
- Level three : Fire steel + coton balls + vaseline. Those kick in when it's wet and windy, or if I have poor kindling/no tinder, etc. They can be ignited with anything : match, lighter or fire steel.
- Level four : Fire steel + rocket fuel (see recipe up here) : this stuff can only be truly ignited with the fire steel, but it will burn very hot and quite long even in the worst conditions. It ignites almost anything if you put enough of it. I usually carry 2 full film vials filled to the neck with them. I keep that stuff for emergencies or if everything else has failed.
Cheers,
David
