Everybody is concerned with drinkable water for survival. I understand the following is very area specific - I could go over a ridge about 20 miles West of me and be in a quit different well situation. Recently was shocking my well (chlorine treatment) when it occurred to me that maybe I didn't need a generator to pump water out of that well. Turns out that in my area it's not uncommon to have a well depth of 160-200 feet - but the water column within the well is only 30 feet or so below the surface.
So -what I'm looking for is - a good ( very reliable) light and reasonably portable pump - hand or foot powered. The trick is to be able to pump a vertical distance of 50 feet or less. Would like a non immersion design because if we are forced to move around - wouldn't want to loose a irreplaceable piece of gear jammed in a well.
Portability of pump and hose is important - but will stipulate that this is probably not going to be a back packers solution. However - if it could be a single person pack frame load including hose - that might be worth schleping around.
Any body got any ideas - models/manufacturers ?
