Purchased a Khukri
Several weeks, I purchased an older khukri for $15.00. The reddish, wooden hilt appears to be a one-piece carved affair with a brass butt-plate. There is a triangle engraved in the center of the butt-plate and there is small, oval-shaped “nut” with decorative lines mounted flush on a bolt in the center of the triangle. The bolt comes up through the center of the hilt and is probably the end of the tang.
The blade itself is 13 inches in length and has the following markings: Tempered STFFI Made in India. There is also a 4-inch groove on each side of the blade that extends from the hilt to where the blade begins its downward curve. I first thought “blood grooves” but they seem to be too high on the blade for that purpose. There is also an “M” or “W” shaped notch on the edged side of the blade just past the hilt. There is some discoloration on the blade and I would like to know if using very fine steel wool to remove the discoloration would be harmful?
The scabbard appears to be made of wood covered with black leather and does not have any type of cap on its end. The top 4.5-inches of the scabbard has very tight leather lacings that run through black metal grommets in an “X” pattern. The back of the scabbard is unadorned but there are two black leather loops braded to the back. The loops have limited adjustability with small silver-colored buckles on the front. Would the loops have connected to a waist belt or to a shoulder/chest harness of some type? I think using saddle soap on the scabbard will help preserve the leather.
On the back of the scabbard there are also two smaller opening to house two smaller knives. However, only one of the original two knives is still inserted into the holster. I have read that the two small knives are called the “karda” and “chakmak.” The chakmak is for sharpening the blade and starting fires with flint and the karda is for skinning. However, I do not know which of the two knifes is present.
Any other information that you can provide me will be appreciated.
Thanks,
dglockster
I can answer that part, unless I get it backwards. The chakmak is a flat piece of steel with a knife handle - it does not have a sharp edge. The karda on the other hand, is actually a small knife, ground to an edge.
I don't think those India kukris are high-quality, but you didn't get ripped off, not for $15.
You should ask your specific questions down in the Himilayan Imports forum. That's where the real Khuk nuts hang out. :)
Best Wishes,
Bob
The nut and "Tempered Steel Made in India" makes it sound like a military-issue khukuri made in India, post WW-II I think. The scabbard you describe fits that ID. But those models have straight handles (with a pronounced swell towards the butt) and no diamond shaped "hiru jornu" (washer over butt plate) -- just a nutt tightened against the brass butt plate.
You may have one of many examples of a military blade that has been modified to fit civilian tastes.
The fullers (grooves) are decorative.
The notch in the bottom of the blade just above the handle is a "cho" or "kauri." There are different theories on what it signifies or what function, if any, it performs.
Thanks to both of you for the information. I appreciate the knowledge that is to be found here. The description of the karda being "a small knife, ground to an edge" describes the small knife that is with the khukri.
The hilt does have a sight curve and it does flair out into more of an elliptical shape (rather than diamond) at the very end. The triangle shape that I mentioned is actually incised into the butt-plate itself rather than being a separate washer.
Also, the location of the "cho," as being above the handle infers that when held in the proper grip, the edge of the blade is in an upward position. Is that correct?
Before posting, I did look at the Gurkha House Forum but no one had posted there since 2002 so I didn't post there. I'll check out the Himalayan Imports Archive.
see pictures on (link follows)
HI website
click on the pic for the 'gurkha brigade' ( the sketch with the chubby gurkha holding the blade in his right & left hands with the edge up is just him contemplating the edge ). the site has lotsa pics of not only various kukhris but pics of gurkhas using & training with them, as well as lots of informative articles on khuks, etc. the lady holding the BIG kukhri is our Aunt Yangdu, 'she who must be obeyed' and one of the finest people about.
The khukuri is typically gripped with the edge downwards.
Gurkha House went out of business years ago.
See ya' at the HI Forum.
