I recently picked up a VECP V2 folder and when I removed the pivot screw the female mate fell out as well. I noticed that it had two opposing flats ground into it. I was curious what the reason for those flats were since they didn't seem to interface with a corresponding flat/notch in the handle slabs or pivot bushings?
In the past when I've seen that used it was to interface with the handle, liners, bushings in some way. It seems like that if they are not interfacing with anything a completely round pivot would be stronger/smoother, but then I thought perhaps they were there to allow a place for pivot grit to escape the bearing surface, or function as a grease "reservoir" similar to the idea behind perforated bushings.
