Hey guys,
I have an old Opinel #8 I got at a hiker's lodge in the Adirondacks when I was at summer camp (well over a decade ago). It is the older model, which cannot be locked closed. I used to rely on friction to keep the blade in the handle, but years of use has loosened the pivot and now the blade falls out if you tip the knife uspide down.
The other day, as I reached into my pocket to grab it, the blade was partially out and it stabbed my index finger. It was a nasty suprise.
I tried filing a notch into the bottom of the blade where the lock ring can slide into when the blade is closed. I don't have a file thin enough to get in there though. I also tried filing off part of the lock so it can close around the blade, like on the newer models, but I live in a city apartment and I don't have access to a workshop with a vice and a good file, just the file on my Swiss Army knife. For the time being I keep it wrapped in a rubber band but this is not a satisfactory solution and I want to improvise a more permanent one.
I could just get a new one for $10 or so but this knife has some sentimental value to it and I want to keep using it. Any suggestions? If I have to hit up a real workshop with real tools and files then I am willing to do that. Thanks for reading.
