Ok so today I decide, screw it I am going to put on my pocket clip on my Jeff Hall folder. So get a 5-40 tap, matching drill bit, thinking that how can this be. Well after the first broken drill bit, using a hand drill with a level on the back of it, it can be kind of difficult. So the bottom line is that I have the holes drilled and tapped. Now the tap says 5-40 and it is a #38 drill bit I used to match the tap. So what screws do I use? Cause the screws I was going to use from an old CRKT won't work. I looked at knife kits.com and they list 4-40 screws? I am assuming the 5 I used is slightly bigger? Yes/no? Anyways any suggestions are appreciated and if you can steer me in the right direction I would appreciate it. Everything came out fine in the end with drilling and tapping too. keepem sharp
