- Feb 15, 2002
Spent most of yesterday and today taking out dead limbs to reduce fire risk. I'm mainly concerned with a 50' defensive perimeter around the house and a couple of acres worth of open meadow. Sure is pretty up there.......
I needed a blade with enough heft and length to reach limbs up to about 8 feet off the ground. And yes, I do have my safety glasses on!
I compared the Bush Buddy to my hand axe - a very effective tool. I like the Bush Buddy a lot more than the hand axe. It's lighter, very nicely balanced, has a long cutting edge, great reach, a super grippy handle - and the sweet spot for chopping is 2-3 inches back from the tip - right where it should be! Plus it will do a lot of other camp type duties easier and better than the hand axe. When it comes to a thicker limb or log - say 5+ inches diameter - the hand axe begins to show a slight advantage, but less than I had predicted. You can see that both blades penetrated to about the same depth when swung with roughly the same power.
This Reader's Digest was no match for Tai's blade.
The Bush Buddy sure makes a clean cut too. Its edge geometry, hardness and willingness to be guided accurately by the hand all out-perform the hand axe. A task such as quickly making a few tent or tarp stakes is child's play for this blade.
After fairly hard use as described above the edge remained unfazed - no surprise as Tai clearly knows how to properly temper his blades. Also, I was very pleased to find minimal shock transmitted to the hand when chopping. I have to conclude that Tai's differential heat-treating of the blade is responsible (hard edge, soft spine). I didn't take the beautiful mahogany scabbard into the field. Instead I corked the tip and put the Bush Buddy in a zipper pouch.
Tai forged the blade from 1095 and though the edge is hard, the plan was to be able to easily put the edge back into shape, if necessary, with a Soft Arkansas stone and water. I ordered the appropriate bench stone from Dan's Whetstones at http://www.danswhetstone.com/
One way to enhance the overall utility of this blade would be to attach a wrist thong. However, it may not really be necessary. I say this because the handle provides great grip and does not slip, even when wet.
While not a thorough blade test per se, my task-specific use of the Bush Buddy yesterday and today left me very impressed (seriously, I mean very impressed) and 100% satisfied!
Thank you, Tai! I'm sticking with you, bro, because you totally know what you're doing! :thumbup:
For additional pictures and details concerning the Bush Buddy, follow this link: http://www.bladeforums.com/forums/showthread.php?t=410088
