Puzzle Lock?
Does anyone have any good video, pictures, or diagrams of how a Bram Frank Puzzle Lock works? From pictures I originally thought it operated like a back lock but in an old Spydercoforums thread Bram Frank mentioned that the principle is similar to a liner lock.
Reading the patent, it's a cross between the two. Locking and unlocking is similar to a liner lock. However, the mating surfaces, being more than a simple bar, makes it closer to a backlock in shape.
Looks like a frame lock and a compression lock hugged a little to long and this was the outcome several months later.
Yeap, looks like compression lock. Can't see the difference between that lock and lock on Spyderco Paramilitary
yeah, the only difference i noticed is the shape of the notch on the back of the blade. the para has a rounded notch and the puzzle lock has a square notch.
Bram Frank said:
As for the lock.. Its not a compression lock..its not a variation on a compression lock..
A locking liner has a tang arm that rotates out and its not a compression lock..and yes a liner could operate from the top side as well as it does from the bottom as it normally does..
the fact that a compression lock and a puzzle lock have back releasing tang arms doesn't make them the same or related by function.
no anvil pin, no compressing action, then no compression lock..
a puzzle lock does NOT compress...
a puzzle lock has no anvil pin or pinning action..
as for overall quality its as good or better..
personally I think its better..I personally choose the materials used.
I think the difference is the compression lock wedges the liner between the blade tang and the stop pin, but the puzzle lock fits the liner into a matching slot in the tang itself. In the puzzle lock patent there's a section that describes the weakness of the compression lock, which seems to revolve around the deformation or loss of the stop pin.
