Just got a Fallkniven PXL today. I picked the maroon micarta handle this go round, after already having had a white ivory model. I had traded that one earlier and made the decision to get another one as soon as possible seeing how I really missed it after it was gone. Of course all the recent threads about the PXL really got my fires stoked for one also. Several observations; the edge on this knife is the sharpest I have received out of the box, sharper even than the BM 610 Rukus, which had held that spot until today. Fit and finish is great, as is the blade action, and lockup. Of course I've never seen a knife I couldn't "improve", and with that in mind, here they are. First thing I did was to disassemble and polish, which did not really require much on my part. Second thing I did was to give the liner a touch more bend, just to get the stiffness I like in my locks. Third thing I did was to replace the teflon washers with phospher-bronze washers. The teflon washers are .015" thick, and my p-b washers were .017" thick, and I was not sure if that would make any difference, but after reassembling, there were no problems as everything lined up as it should. The blade action is really slick. The last 1/8" of blade travel before closing really shows how well everything lines up and the precision of manufacturing. The blade just seems to be sucked into the closed position and you can see the liner snap over as the ball detent and blade hole are in perfect alignment. The pb washers I put in were polished and I used miltec as the lube. As slick as the action is out of the box, it seems to be even slicker now! The only other thing I did was to cover the pocket clip with my standard black 3M Stair Step tape that not only subdues the shine, but helps with drawing the knife out of my pocket. On another note, the first PXL I had had a serial number on the blade spine, somewhere in the 300 range I believe, but this PXL is unmarked on the blade spine. Was there a certain number that were serialized? I guess the absence of a serial number would indicate that this one has the properly heat treated pocket clip. I guess that wraps it up as the PXL has graced my pocket since it came. I did notice that it is lighter and smaller than what I usually carry, but man do I love that blade steel and how well it cuts!
