Look in local shop for glass ....they have it for the stoves .Hey guys,
does anyone of you know where to source pyroceramic liners for beltgrinders in Germany? As for now I was unable to find anything usefull.
Kind regards
Tolga
They will cut dimension you ask for , you need to sand little edges and that is that .Was it already in the right format or do you need to process it until it fits properly?
If you can t find glass you can use ceramic tile ..............Was it already in the right format or do you need to process it until it fits properly?
I get mine from eBay. Just search "robax" and sort by lowest price first. The seller is named "hidden_treasures_of_LA" if I recall, and the standard length is 2x8, though they will do custom/other sizes if you send them a message first. I've ordered several from them, and they've all been cut square. They're only about 3/16" thick if I remember right, however. Is there a reason you need 1/4"?I can't source any that is thick enough and cut with the edges square.
Anyone know where .250" can be had?
I have a 1/2" thick platen backer that has a 1/4" deep by 8" long pocket cut out.I get mine from eBay. Just search "robax" and sort by lowest price first. The seller is named "hidden_treasures_of_LA" if I recall, and the standard length is 2x8, though they will do custom/other sizes if you send them a message first. I've ordered several from them, and they've all been cut square. They're only about 3/16" thick if I remember right, however. Is there a reason you need 1/4"?
