Q: Any suggestions for thinning an axe head?
Good day all!
I'd recently visited my brother in law. He was sharing that he felt like his axe wasn't up to the task of breaking down larger chunks of wood into smaller chunks. He's not a woodsman. He's just trying to get wood to a size that will fit in his Solo stove.
When I checked the axe, it seemed a bit dull. TBF, I'm no woodsman either.
Of course, I decided that it would be interesting to see if other folks have done things to improve the performance of their wood cutting tools.
One that jumped out at me was this video from Outdoors55:
He discusses the idea of thinning out the blade and then sharpening to be able to more effectively cut. Same principle with kitchen knives-geometry matters.
I'm curious if others on this site have tried this technique of thinning the axe head for better cutting performance and if so, what the results were.
Thanks in advance!
Bruce
BF member 'HeavyHanded' was very knowledgeable about such things. He hasn't posted in a long while, so I don't know if we'll hear from him directly. But I linked one of his posts in an old thread along the same topic lines. There are good tips by others in that thread as well. Most who seem to know about these things often recommend using a powered grinder (if you're experienced with them) or a very large mill bastard file for quicker metal removal. HeavyHanded demo'd that file technique on a hardware store hatchet in his linked reply below, with one of his own videos. He also used what he called a 'washboard', a device of his own design that used a grooved device he made, wrapped with a sheet of wet/dry sandpaper or a sheet of plain paper with compound, for the finishing and refining/polishing passes.
You might find more good tips from him if you search out more of his old posts here on the forum.
I don't do it quite like he does, but the principle is similar and I agree with his premise. Axes as a general rule tend to come too thick behind the edge even if the apex angle is good. I work the cheeks backwards and forwards on the contact wheel of my belt grinder to produce a deep and gradual convex deeper than you can achieve with a typical slack belt.
Different site but this is a good thread on profling axes.
Sounds like your BIL could use a splitting maul instead of an ax.
Even those are typically too thick right behind the edge and perform better sharp. You'd be amazed at the difference thinning behind the edge makes with splitting mauls. Wedges, too. All of my splitting wedges have a thin convex at the edge and they drive easy and blow right through wood compared to their factory geometry.
My best splitting ax was an old double-bit worn down to a convex edge.
