James, I am currently sharpening an SRK for a friend of mine who uses it for his nat'l guard duty. He doesn't know much about knives but he sure knows how to abuse them. This one looks like it was sharpened by a drunken monkey using a cinder block as a hone. So, I'm filing it down and figured I'd check things here for tips and found your post. Seems I'm already following the standard practice for the SRK by filing it
As for the coating: my friend has used this knife to open oil cans (often!) and the coating is a little marred, but still intact. The sheath is in excellent condition.
As for CS replacing sheaths, I know that for some of their knives they sell the sheath seperately. I busted the cheap plastic sheath on a readyedge a while back and they replaced it. My CS Tanto sheath started to tear a bit and I managed to stitch it up myself.
Anyway, I like the SRK well enough, but I have to recommend that if you don't have at least a smooth file that you pick one up and not try to hone it down -- I'm already getting worn out filing!
I'm thinking I'll put a fairly good edge on it, not hair-shaving sharp but close to it, for the kind of abuse he gives this knife. I'm wondering whether it might be good for him to pick up a butcher's steel to touch up the edge, rather than using a cinder block. Think this will work on the Carbon V?
Eric Sakowski
Signal Post, Inc.
http://www.signalpost.com
