Duffy, I'd have to go back and look at the book to see exactly what they did, it's been a long time since I read it. I have the Loveless video, and they use a whole lot of fixtures in order to get the knife fit together.
Here's my take on this situation----
You profile the blade and drill the holes through the tang while the stock is flat.
Then you go to the grinder and taper the tang and heat-treat the blade.
Now you need to fit the scales.
IF you lay a flat/parallel scale on the drill press table and then lay the (now tapered) tang on the scale, the holes in the tang ARE NOT IN LINE WITH THE SPINDLE ANYMORE. Capitalized for emphasis.
Maybe a guy can fudge this by using something with liners and colored epoxy, but do it with a tapered tang that has surface ground flats, lapped ivory scales, NO LINERS, and YOU WILL HAVE ISSUES.
The reason no one ever tilts the drill press table is because it's too much of a PITA to get it back to perfectly square to the spindle compared to using a simple fixture and never having to mess with the table.
Another reason it's worth having a SIMPLE fixture like that one I have, is for drilling stag or ivory scales that are only flat on the inside (tang) surface. People can argue about whether you can lay the scale on the table with a tapered tang (even though they're wrong :foot
but there is no way in hell you can lay a piece of textured stag on your drill press table and get it to lay flat. No way.
