QCB1 Camillus Bob T knife PICS
I got my hands on a CUDA-Terzuola CQB-1 today. CQB = Close Quarters Battle. Your mission, if you choose to accept it, is to come up with a politically correct alternate spelling-out of that abbreviation (something meaningless like CUDA Quantum Blade?).
Click on the small picture for the big picture.
<A HREF="http://www.chaicutlery.com/Camillus/CUDA-CQB.jpg" TARGET=_blank>
</A>
(1024w "wallpaper size" image)
The "CUDA Slik-Matte" finish is non-reflective, but much more pleasing to the eye, and probably easier to keep clean, than the bead blast on the current CUDA folders. The grip is comfortable - unscientific survey of me and one of the ladies in our office. Very sharp out of the box. Feels solid. The top edge is not sharp, and not sharpenable without power tools, but it could easily be mistaken for a "dirk or dagger," a consideration of you plan on using that IWB carry strap they supply.
The sheath is from Blade-Tech, the same place that does the very similar sheath for the Spyderco Moran. Very versatile carrying system, multiple positions. I have one nit to pick with both the CQB sheath and the Spyderco Moran sheath, namely that when you push off with your thumb the two halves of the sheath pull away from each other and then snap back, pinching your thumb. This effect can be made less annoying with a minute or two of scraping the inside edges of the kydex with the point of a small knife to create a bevel in place of that sharp right angle.
The black canvas micarta grips are have a terribly practical tactical non-slip blasted finish that is just begging me to touch them up with a sanding belt, and then some hand-sanding, and 0000 steel wool. I'd be tempted to go totally un-tactical, but the idea of buffing anything with a blade that sharp scares me.
- JKM
www.chaicutlery.com
AKTI Member # SA00001
Web Site At www.infinet.com/~browzer/bldesmth.html
New Web at www.darrelralph.com
This thing is eye catching to be sure. Does Blade Tech use a decent thickness grade of Kydex for the sheath, or is it flimsy? How does the IWB attachment actually attach? Thanks. Professor.
In my opinion, that IWB attachement is the best thing since sliced bread. If I'm right, it is the same pull-dot snap strap that Blade-Tech uses for their handgun holsters. It is a fairly robust piece or rubber-type polymer. It attaches to the sheath with a screw and aluminum post, through any of the various holes in the sheath. The phillips-head screw is nested inside the snap. It is hell-for strong, and works like a charm. I fit all my kydex sheaths with them. I have 4 of those straps on the way for just that reason (along with the kydex to make a few sheaths for my knives that didn't come with them).
IMO, with one or two of those straps, you don't need the tek-lok.
inktomi
