- Nov 3, 2020
I need a source for a quality file for profiling axes. Nicholson files are no longer good or reliable since they are being made in Mexico and Brazil. Most European files seem to be out of stock everywhere I look.
http://www.grobetusa.com/8-INOX-hand-file-cut-00-item-30-213v/I need a source for a quality file for profiling axes. Nicholson files are no longer good or reliable since they are being made in Mexico and Brazil. Most European files seem to be out of stock everywhere I look.
I'm not familiar with how they further harden them beyond what is attainable by conventional methods. As you say, I think it's done chemically.
Nor can I really vouch for them being that hard, because I don't have testing equipment nor any real experience in determining hardness.
All I know is when a brand new Nicholson skates, it's time to grab the Inox!
The one I'm currently using is 00 cut, and it produces filings so small that it works great on mushrooming too. You very rarely have to clean the file out. Just wipe the filings off every so often.
What I'd like to know is this, let's say for the sake of argument that their advertised hardness of 72 is correct. What is the maximum hardness an HRC72 file can cut? 68? 70? 72?
Because I have several hatchets, dinne chisels (of course) and a couple axes that this file just can not cut!
I'm talking stupid hard. Knock your socks off hard! Diamond stones were the only way to achieve an edge. And lots of time.
The Inox files do last though. I've learned be mindful to not tap the file back down on to the axe after resetting to begin another file stroke. They are so hard that I broke tiny pieces off from many teeth doing that with my first one. This second one is over a year old and still cuts unbelievably well.
I've been at it long enough to know that man.Chances are good, in that case, that the file itself is a conventional file of good, high hardness, but then an additional coating is applied to create an extra hard skin on the outside. Hardness testing files are usually graduated in steps of 5 RC, and materials of equal hardness will scratch one another. The larger the difference in hardness the more effective the cutting action will be, and the less wear will occur to the abrading implement. In the case of axes even your Inox file skates on, the skin has probably worn off of the teeth on that one and/or you may be dealing with a layer of magnetite (black oxide) on the surface of the axe, which is about 70 HRC. Scuff up the surface with a sharpening stone to reveal bright steel and see if it'll bite then.
