Quartermaster QSE-3, which information is correct?
Are these 2 different models or something? BladeHQ and Knifecenter both seem to have the same models, but they both have slightly different information regarding the knives. For example, Knifecenter's version:
http://www2.knifecenter.com/item/QA...tonewashed-s35vn-tanto-blade-black-g10-handle
Quartermaster Knives QTRM5TR QSE-3 Sonny Crockett 4" Stonewashed
Features the Tri-Spoke pivot assembly without the ORB pivot system, however the sheer weight of the blade makes for easy actuation from the handle.
Blade Length: 4.00" (10.2 cm)
Blade Thickness: 0.165" (4.2 mm)
Handle Thickness: 0.550" (14 mm)
Overall Length: 8.75" (22.2 cm)
Weight: 7.4 oz.
Carry Type: Pocket Clip
Locking Mechanism: Frame Lock
Pivot Assembly: Tri-Spoke without ORB System
Then, the BladeHQ version:
http://www.bladehq.com/item--Quartermaster-Knives-QSE-3-Sonny--21848
Quartermaster Knives QSE-3 Sonny Crockett Frame Lock Knife (3.75" Stonewash)
It features the ORB Pivot System, a sealed ball-bearing that is incredibly strong and smooth
Blade Length: 3.75"
Blade Thickness: 0.16"
Weight: 7.40 oz.
Model: QSE-3
Is there a slightly longer version without bearings, or a version without bearings? If so, they should add a letter to the model name or something.
Same knife. Knifecenter's specs and commentary mesh up with the info at QM's official site. I think the shorter blade length and mention of Orb bearings are just goofs on BHQ's part. :thumbup:
Are these from the China shipment? :)
OP, stay away from Quartermaster, they have some ongoing issues/concerns.
No reason to think they aren't based on that shipping manifest. They appear to be reworked Mantis knives.
Sorry about that. We fixed the description about the ORB pivot, the knife does not have bearings. The blade length on our listing is correct, we measured that here.
