- Dec 19, 2006
I have concerns about buying knives made by Queen since I've experienced a lot of problems with their knives over the years. The finish on the handles is usually very good but i've experienced problems with the construction/mechanics as well as very disappointing grinds.
From prior experience, I assumed they must not intend for their stainless knives to be used. There have been a few exceptions (such as the Queen made Robeson knives) but most of the 420HC knives had very poor grinds in comparison to their knives with 1095 blade steel like the Moore Makers and Winchesters. My experience with their D2 is more varied. I assumed they made the 420HC Schatt & Morgan knives to sit in a display case (they don't need to cut anything) and they made their 1095 Winchester and Moore Maker knives to be used.
Their 420HC main blades tend to be thick and often have extremely thick points. The small blades are usually ok but I'd describe some of the main blade profiles as thick and oval shaped.
I wasn't sure what the grind would be like on their ATS-34 steel. I hesitantly bought my first Queen-made knife with ATS-34 steel and I just received the knife today. Although it doesn't have the ridiculous oval profile that I've seen on some of their knives, it's still not going to be a good user without some modification. The blades are as dull as a spoon but they can be sharpened. The problem is the profile. It's fairly thick which isn't necessarily a problem. The problem is that it gets thicker toward the point.
They did put a swedge on the blade but it appears to be just cosmetic. A swedge is supposed to thin the steel at the point. But the swedge is deepest where it doesn't matter and it's almost non existent near the point. It's also uneven on the front and back but that doesn't affect function.
In order to use the knife, I will either have to take up part time knife making and fix the swedge myself or pay someone else to do it for me.
Here's a scan of the Moore Maker (1095) and a Schatt & Morgan F&W series (ATS-34) clip blade for comparison. Both knives are 2-blade sowbellies. It's raining so I wasn't able to take the knives outside for a photo but hopefully you can tell from this scan.
Moore Maker on the left, Schatt & Morgan on the right
