i recently received 7 knives from Bill at Cumberland (very friendly and helpful).
of the 5 Queens, one, mini folding hunter arrived not sharpened at all. under 10x magnification the polished metal went right to the edge, no grind marks at all. the others are reasonably sharp but using my edgepro, the angles are all greater than 24 degrees per side. there is about 1 mm. of untouched metal at the blade edge at 24 degrees. otherwise fit and finish on all is fine.
the Moore Maker (serpentine stock) is a very sweet knife, the kind you don't want to put down once in hand. it's grind is even steeper (40 degrees ? per side).
the Canal Street (ring opener) is also a tightly made little knife. sharp and at 24 degrees per side and the only one with edge angles nearly equal on both sides.
so, other than edges, all are well made without problems. the MM is the most expensive, but i think worth it, especially if you don't want stainless.
question: so now i have 15 blades to work on with my edgepro, what angle do folks recommend for the D2 blades, and for the 1095 ?
