- Jun 16, 2008
Well I have a pair of long needle nose pliers, and that may be behind the whole dilemma. I have read that you need to get steel from austenized state to under 400 degrees in under one second. I may be remembering wrong. I have a pair of wolf tongs on the way and I will be testing my "moves" with those. So far the welding gloves I have are kind of bulky and it took a bit before I found a way to handle them proficiently enough to pull the blade form the oven and into the quenching oil. These are dry runs with the HT oven off and no oil in the quench container mind you. From the time I open the door to the time I get the blade into the oil is around 2 seconds more or less. Is this fast enough or is it one second from the time you open the oven till you get it into the oil? The temp starts to drop as soon as you open the oven correct? I will be using 1084 to test my new oven btw. Thanks!
