- Dec 24, 2015
Further to my 1095 questions,can it be quenched in the foil? If not, how do I get it out of the foil and into the oil in a matter of seconds?
No, it won't work. 1095 is a shallow hardening steel with a pearlite nose of only a fraction of a second. Anything that would slow down the quench at all will make it not harden.
Additionally, there should be no reason to HT 1095 using foil.
I think you may be mixing up HT info from carbon steels ( like 1095) and stainless and tool steels (like 440C). They have very different procedures and the high temp processes use a foil packet.
There are some anti-scale coatings used on carbon steels. Turco and PBC are two of them. They protect the steel from oxygen during HT. Most folks don't use them. The entire blade will still need re-sanding after HT anyway.
You say most people don't use them ( Blade anti-scale coatings).....
Is there a pro or con to this, as of why?
