Fred,
Some few months back Bruce Bump bragged up Brownell's PBC to me and I bought some. It works up to 1650 degrees F, so the label claims, and I like using it very much. It cleans off the quenched blade in a couple to a few minutes in boiling water (a practically perfect temperature for holding a high carbon steel prior to temper). It is specified that the steel be heated to about 500 F and then coat with the powder. I have found my best results in consistant coating to occur if I hold the steel moderately above 500 F for several minutes to allow to equalize, then coating. I recommend Brownell's PBC Non-Scaling Compound. (VERY IMPORTANT: DO NOT allow it to stand in your heat treating oven. Use stainless wrap or an alternative material to catch any droppings or residue so that it can be removed from the oven after using. My reason: higher temperaturers, those for heat treating stainless steels - as an example, will cause the residue to eat steels and I don't know what else. Keep it off your refactory bricks and your electric elements and your thermocouples.)
RL
