Quenching
So, I've done some reading, with regards to heat treating O-1, and a few questions have come up that forum searchs and the web haven't answered.
- how big a quench tank do you need? hidden tang blade of O-1, overall length is 8", max thickness 3/16".
- when quenching do you plunge the blade straight in and hold
- plunge edge first and holde
- straight in or edge first, and stir?
Basically, how do I quench?!
Thanks,
~ Dagr
bout all i can help you with is that most feel that 1 gal per pound of hot steel works
so far as how to i dont realy oil quench sorry
i do know some just do the edge and others do the blade virtical and others still do it horazontal
I use a large volume of oil (5 gal.) I dunk the blade in vertically point first.
Scott
You have a choice of vertically or edge , NOT flat which will warp the blade . If you're using a 5 Gallon bucket point down is convenient. Move the blade back and forth [not side to side ] .
sorry mete i should have said point first or whole edge all the way or just edge
flat will give you a hell of an arc
thanks
