- May 23, 2008
I just got into CRKs and I've picked up quite a few on the Exchange here. All of them have been great but I just noticed an issue with my 2010 Small Sebenza 21 Insingo while I was messing with all of them tonight. The pivot screw was about a half turn loose so I tightened it and the blade become pretty difficult to move. I've got several other 21s (small and large) and I can tighten all of them completely without affecting blade movement, which is a benefit of the pivot bushing if I understand it correctly. The knife is LNIB but I tore it down to take a look. The internals were bone dry so I greased it and reassembled but that didn't fix the issue. I was a little worried that it might have been a clone but I tore down my large 21 Insingo and one of my other small 21s (both 2010 models) for comparison and everything looked spot-on. The date codes are on the scales and the blade pivot hole even has the small cut-outs inside. The things that made me question it are the finish is much smoother than any of my other CRKs and the CR logo is cut deeper than on any of my other CRKS. Otherwise I can't see any difference.
Anyway, my guess is that one or both of the pivot washers are a little too thick or the pivot bushing is not quite wide enough. Should I just send it to CRK and let them have a look at it?
Both of these were bought on here from the same seller who has excellent feedback. I doubt you can see the difference in finish between them but the small's is much smoother. None of my other CRKs are like that. All the others have more texture and they seem to be equivalent in that area aside from the knife in question. The extra light reflection off the rounded areas is an indication of the smoother finish. You might be able to see the deeper logo cut though. Has anyone seen either of those attributes? Any insight would be greatly appreciated.
These are some of the others I've picked up and I've disassembled most of them. So while I'm new to CRKs I have poked around in quite a few of them recently. By the way, that small Classic with micarta inlays is my favorite. The action is so smooth and it's just an awesome little knife.
