Question about AMS
What the different between Anniversary Mean Street limited edition and Anniversary Mean Street CG?
What CG stands for?
What means double cut on blade finish choice?
does it worse it to spend additional 90$ just for name limited?
Is Anniversary Mean Street limited edition still get individual numbers or not?
Cg means combat grade. Double cut is like a dull satin finish. Limited is more because it is satin which takes more time to finish.
Limited Edition: Satin finished blade, numbered & special handle material. (Sometimes with different grind or blade shape.)
CG: Combat Grade. Comes with a coated blade that requires less labour therefore cheaper. Often thicker than the LE and with slightly different shape or handle material.
Double Cut: Bead blasted 'frosted' appearance on the blade.
The $90 is for the collection value and labour on the satin blade. It is worth it if you like a satin blade!
Double cut is actually bead blasted with two different mediums, so really blasted twice, hence double cut.
From top:
Double Cut Anniversary Mean Street
Satin Leaner Meaner Street
Combat Grade Active Duty
Satin Game Warden
Satin Magnum Bear Cub
