There are several reasons for the chisel grind. For any of you who have ever used a correctly sharpened wood chisel for woodworking, you know what a chisel can do. Although a knife is not a chisel, those properties, when applied to a knife grind have almost magical effect. A chisel ground knife, being beveled, (ground) on one side only, possesses greater strength, (due to increased cross sectional mass) and they cut with an ease not found on any other type of blade. This is because there is no parasitic drag produced by the flat side when cutting --- no drag points. On top of that, they are much easier to sharpen --- you only have to sharpen one side.
