I have a Ka-Bar D2 Extreme knife. I'm thinking about removing the blade coating to make it look better. How to remove it? Does the D2 steel will rust quickly without coating?
Just rinse off the knife and sheath after the dive.
It is not as bad as high-carbon blades, with minimum care it shouldn't rust at all (unless you live in a tropical rainforest).I have a Ka-Bar D2 Extreme knife. I'm thinking about removing the blade coating to make it look better. How to remove it? Does the D2 steel will rust quickly without coating?
It's VERY wear resistant, holds a great edge, it gets hard as hell and it should be tough enough unless it had a bad HT. Can't really go wrong with D2, just get some ceramic or diamond rods to deal with this animal, because D2 ain't exactly the easiest steel to sharpen.Some knife manufacturers are saying that D2 is "the toughest steel used in knifemaking". Is it true? Is D2 really so good?
