- Dec 25, 2009
I was wondering if damascas blades have any advantage over non-damascus blades, or if it was purely cosmetic.
i think that the ancient Damascus blades were a kind of superdooper steel. apparantly (from guff i've read), the forging process resulted in carbon nanotubes or similar being formed within the steel, making it legendary for strength.
however, as i understand it (and please correct me if i'm wrong), the secrets of "real" Damascus steel have been lost.
i've heard that some Russians found a forging technique which led to some very strong Damascus-like steel in the mid 19th century.
is it better or worse than, for example, laminated VG-10? i don't know. the only way to really find out would be to get a Damascus blade and a Lam VG-10 blade, swing them at each other and see which one breaks first (not something i'm in a financial position to even contemplate).
i'm sure some more knowledgable members than me will chime in.
This seems like the appropriate thread to throw out a question I have been curious about for a while...
Since everyone says that modern steels have the advantage of being pure, what would happen if you made damascus out of modern super steels? More importantly, would there be an advantage in the layering? Would it be similar to a laminated blade, but somehow better?
I honestly see the benefit of laminated steels (or aka San Mai) but not really for damascus except for aesthetics. In the case of San mai/laminated steels, there is a clear benefit of the more corrosion resistant and tougher outer layer and with a harder and more edge holding core. Not necessarily in these combination of benefits but you get the picture I hope.
In the case of damascus, unless it is proven that the layering effect does stop cracks from propagating, I'm unsure if it's an advantage or not. Also in damascus you have to see what are the combination. There is almost limitless possibilities and different combination have different features.
A century or so ago, gun barrels were also made of Damascus steel. Folded around a mandrel and hammer/forge welded.
One, at least, of the earlier "Damascus" steels was made by forge welding a strip of steel and a strip of pure iron, then folding it and reforging numerous times until you had several hundred layers of iron and steel. This allegedly gave the blade good ease of sharpening, while maintaining good strength and edge retention.
Whether or not this process has any advantages over today's better quality single steels is open to debate.
Some knives, especially Japanese kitchen knives use a laminating process with a top end steel like VG10 in the center of numerous folds of a lower end steel such as 420JC. This protects the VG10 from impact, and allows it to be hardened well beyond the capabilities of a regular VG10 blade.
An old time Damascus blade would have an even number of layers, since each time it was folded, the number of layers doubled. A modern Japanese laminate will have an odd number of layers, because of the insertion of the "core."
